Old 05-08-2010, 08:55 AM
Buick Motorsports's Avatar
Buick Motorsports Buick Motorsports is offline
Default Locking Header Bolts for SBC
What are the best ones out there? My 406 loosens regular bolts with ease.
Jason
Project No Mercy
85 Buick Regal
BUDGET BROKEN.....SO IS MY SPIRIT.....TILL SPRING!!!
Old 05-09-2010, 05:24 PM
86Cutlass383SR 86Cutlass383SR is offline
I've used both Stage 8 and the Percy's, formerly Breslin.
The Stage 8's are good if you can get the bolt in a certain position to get the lock tab and e-clip on. I had trouble getting all the tabs on.
I then bought the Percy's Split-Lock bolts. Screws in just like a regular bolt, and then after tightening, an allen set screw in the center of the bolts expands the end so it can't come loose.
I used the Percy's bolts (original maker Breslin was bought by Percy) and the aluminum Percy's Seal-4-Good Header Gaskets and never had a header gasket leak in over 2 years. No, I'm not affiliated with Percy's. I just like their products, they work!
I vote for the Percy's Split-Locks.
Doug Gulley
86 Cutlass Supreme, 383 needing a rebuild, AFR 190, Accel SuperRam, 30# SVO inj, 58mm tb, AFPR, Comp Pro Magnum 1.5's, Comp Cams 280 XFI hyd. roller (230* 236* .576" .570" 113*) Tremec Aftermarket T56, C5 brakes, Rondell 58 17 x 8.5 wheels, *under construction*
I can explain it to you, but, I can't understand it for you
Old 05-09-2010, 09:28 PM
Musclerodz's Avatar
We sell and use the Percy's locks in the shop. Love them. let me know if we can help
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-10-2010, 05:12 PM
Do the Percys!
They work and never loosen... Love mine.
Old 05-11-2010, 10:15 AM
Thanks for your input. Looks like I'll be ordering Percy's.
Jason
Project No Mercy
85 Buick Regal
Old 12-13-2013, 01:22 AM
The T-man The T-man is offline
nice...
Old 12-13-2013, 01:36 AM
mnm99 mnm99 is offline
Using same here
