Old 05-23-2010, 06:15 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Default What do you got in your rear end?
I know--bad title.
So I scored a Fab Nine housing, now I need some recommendations on what to run for a third member---the motor I have going in the car is approx 540hp and 550tq---I have a procharger for the motor, but it won't be going on until next year--but I would estimate 700 to 750 and at least that much torque. Will be using the car for mostly street, but road course for sure--at least 4 to 5 times during the year and plenty of auto X stuff.
Doug
Old 05-23-2010, 07:08 PM
I'm not going to respond based on the title!
Seriously -- are you asking about axles - third member strength - gear ratio - yoke sizes or what - or all of the above?
Old 05-23-2010, 07:19 PM
DFRESH's Avatar
Ya--all of the above---what is considered a really good third member setup for one of these cars---who's ring gear are you using---axle spline--etc.
Old 05-23-2010, 07:39 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Strange & Moser is all I use!!
Cris Gonzalez
Old 05-23-2010, 07:52 PM
ironworks's Avatar
If no slicks 31 spline will do. The ratio depends on trans and overall intended use. The true trac is a pretty stout unit, but only available in 31 spline. Just buy good parts.
Old 05-23-2010, 08:40 PM
I agree with Rodger. I would put a 31 spline Tru Track in it were it me, you will never hook it up enough to break it. If your going to do the 750HP set up and run slicks I would do a 35 spline Moser Wave Track.
Frank Serafine
I use Strange housing and gears... Dutchman axles...
Agree - 31 spline is plenty - with a 1350 u joint...
I'm running an Aluminum housing (Strange) in the Nomad - I wouldn't recommend that for a street car.. don't ask me why I did it ("because" is the only answer).
Old 05-24-2010, 01:43 AM
deuce_454's Avatar
OR you can install a strange engineering 12 bolt drop out center section with a 33 spline true track and get the added bennefit of the lower weight and lower parasitic drag of the 12 bolt... best of 2 worlds
Jake: Hit it.
