Old 05-25-2010, 06:50 PM
NovaJ NovaJ is offline
Default Nova & Camaro Fuel Tank Differences
What, if any, are the differences between a 68-72 Nova tank and a 67-69 Camaro tank?
Reason for asking is that I am researching the fuel system for my LS swap and was looking at the Spectra EFI tanks, but they don't produce them for a Nova. I assume that the two tanks are fairly similar due to the other similarities between the two cars, but wanted to check and find out.
Any help is really appreciated.
Old 05-25-2010, 07:03 PM
NvrDun71 NvrDun71 is offline
Interested in this as well, I assume the difference may be in the filler neck location tho?
71' Nova - LY6, T56
Old 05-25-2010, 08:36 PM
LowchevyII's Avatar
LowchevyII LowchevyII is offline
might want to pm 72novadriver. i know he used one on his i think. however he put the fillerneck in between the taillights
Jeff Weidner
1970 nova in pieces
Old 05-26-2010, 05:15 PM
So far, the only difference I have been able to find is the filler neck is different. In which case, I would think that it would not be a big deal to make a new one, or bend the existing Camaro or Nova filler neck to make the Camaro tank work in a 3rd gen Nova.
Old 05-26-2010, 06:25 PM
realcoray realcoray is offline
I was looking at using a camaro tank on my 72 nova and I found some dimensions in ebay ads that indicated the dimensions were slightly different. I can't recall exactly but it didn't seem like it would require much work if any to use a camaro tank (except for the filler neck stuff of course).
