Old 06-03-2010, 01:02 AM
jannes_z-28's Avatar
Default 67 Chevelle with ATS steering arms?
I am helping Alex396ss put together all the good stuff he has bought for it.
I have a question regarding steering arms and outer tie rod ends.
We have Hotchkis control arms and AFX tall spindles and ATS steering arms for A-body.
On Hotchkis website they recommend tie rod ends for 78-88 Chevelle but how does that work with the ATS steering arms.
Is the original A-body 64-72 tie rod ends better for this setup?
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 06-03-2010, 07:41 PM
Vince@Meanstreets's Avatar
The ATS arm tie rod hole is based around the stock A body arm hole so I believe it is safe to say yes. You might want to email Hotchkis about back ground reasoning with that recommendation. Maybe a stronger ball?
Vince
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 06-04-2010, 08:19 AM
Blake Foster's Avatar
the "G" body outer tie rod end had a different taper than the "A" body
you must use the original outer tie rod end for the Chevelle
Blake Foster
www.speedtechperformance.com
