Old 06-08-2010, 06:53 PM
out2kayak out2kayak is offline
Default Multiple Master Cylinders
I've noticed several builds using multiple master cylinders and am curious why folks run this sort of setup and is it worth the extra time / effort / cash to implement.
Thoughts?
-- Joe
Old 06-09-2010, 08:12 AM
Payton King's Avatar
Default I like mine
but we made a custom unit and it too some time to get it just right. To do it again, I would buy a pedal set up from Tilton and graft it into my project and alter the pedals if need be to get around the steering column.... if that is causing a problem. Get the 6.1 or 6.2 ratio unit.
With the dual masters, you can size them correctly for the front and rear calipers and use the balance bar to fine tune.
I did mine for the look at first and then I found that i really like the feel of the brakes. If I were to build another I would do it again, but there is some work to get a dual dialed in.
Old 06-09-2010, 11:24 PM
The WidowMaker's Avatar
not on the road yet, but i had to do a lot to make the wilwood triple masters mount correctly. i just wanted the added adjustablility.
"The WidowMaker"
