Old 06-16-2010, 02:45 PM
dlouie87's Avatar
dlouie87 dlouie87 is offline
Default What do you guys think about these gauges?
I was going to go with autometers but i need to save my money for other things.
http://www.newvintageusa.com/2020series.html
what else would I need to make these work on a ls1 67 camaro? a different sending unit?
would these fit on a covan dash?
or maybe go with dakota digital?
-Dan
Old 06-17-2010, 01:42 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Dan
Glad you like the gauges
They will fit standard size holes like in a Covan dash-3-3/8 and 2-1/16
The 2020s have a clean look, we have a couple of other styles that have different, period looks too. I am a bit partial to the 69 and redline series.
Let me know if you have any questions
Mark
Old 06-17-2010, 02:20 PM
Rhino Rhino is offline
I've been bouncing between those and the 69 gauges for my build. I think the 2020's are growing on me.
Mark, you wouldn't happen to offer the tach and speedo in a larger version would you?
Old 06-17-2010, 02:38 PM
dlouie87's Avatar
Originally Posted by marks914 View Post
Dan
Mark
I'll be calling you after work... if you aren't open, I'm going to pm you my email so we can keep in touch.
Old 06-17-2010, 07:39 PM
very very nice! do they come in 4 inch for the 67 stock cluster?
Can you get them with blue ilumination>
Old 06-18-2010, 05:57 PM
marks914's Avatar
Regular User
Guys,
I would say over half of our business is custom, so we can build pretty much any look you want. We also have larger cans that we can use. The custom work isn't cheap but its available. Probably less than you think, most custom sets run in the $800-$975 range, still less than some of the competitions regular prices
How do we do it? Cheap rent in a small shop and few employees.
Mark
Old 06-18-2010, 09:57 PM
JRouche JRouche is offline
I looked at the vids on the site and read all the info. Im impressed!! They look like some very nice gauges.
Id like to see a tach sweep. Not that it matters much, Im sure its accurate. But the smooth sweep might be something to get used to. Where most tachs have a pretty quick jumping needle for rise and fall. The stepper motor needle movement will be smoother looking. Prolly just as accurate if its fast enough. Just a smoother rise and fall of the needle. And again, not that it matters much, its just a tach, just might need to get used to the sweep of the needle. More of an electronic gauge then a mechanical one.
I really like ALL the options re: lighting and limit sets and alarms.
Sounds like a good modern setup. JR
Old 06-20-2010, 07:10 AM
marks914's Avatar
Regular User
Most of the competition uses air-core movements, which are actually slower to move than a stepper motor, which is why we use them, fast and accurate.
The other advantage of a stepper motor is it gives feedback to the microprocessor ad to the pointer position, which is a double check for accuracy
Mark
Old 06-20-2010, 11:37 AM
brans72 brans72 is offline
Impressed, shame I got Autometer gauges already.
Old 07-05-2010, 12:41 PM
roddr1968's Avatar
roddr1968 roddr1968 is offline
I'm waiting for the 67-68 3-in-1 gauges to come out this summer for my project....
