Old 06-21-2010, 08:14 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default Steve Rupp's 5.3L LS Build
Where can I find details on the 5.3L that is on Steve Rupp's F-Quick garage site? I thought there was a thread on it, but I can't find it on this site. Any ideas?
Chris
Old 06-21-2010, 08:18 AM
jy211's Avatar
jy211 jy211 is offline
http://www.camaroperformers.com/cama...ine/index.html
Old 06-21-2010, 01:37 PM
ItDoRun's Avatar
That's it. Thanks.
Chris
Old 06-21-2010, 01:46 PM
ItDoRun's Avatar
Will the F-Body accessories bolt to the 5.3L iron blocks? I know the 6.0L blocks need a hole drilled for the alternator bracket, but I'm curious about the 5.3L blocks.
Chris
Old 06-21-2010, 05:29 PM
Steve1968LS2's Avatar
all the bosses are the same.. so anything that will bolt onto a 5.7, 6.0, 7.0 etc will bolt onto a 5.3L (and vice versa)
Makes picking a pulley system simple
Old 06-21-2010, 07:28 PM
awr68's Avatar
awr68 awr68 is offline
That's a nice motor that you put together Steve!! Can't go wrong building one just like it Chris!!
Tony
'68 Camaro
Old 06-21-2010, 08:06 PM
camcojb camcojb is offline
just remember the iron blocks are not identical to the aluminum as far as front accessory drive bosses, though you can drill/tap enough holes to make most of the drive systems swap.
Old 06-21-2010, 08:43 PM
Sorry, this is true.. I don't work with iron so I forget.
All the alum blocks, including the 5.3L alum have the same bosses I believe.
Old 06-21-2010, 08:45 PM
I still cant decide which one to put in the Track Rat.. the 454 would be more fun but the 5.3L would stay with the spirit of the project (lower buck/midrange buck)
I want my next project to be really low buck, gritty, primered, light and cheap..
Old 06-21-2010, 09:09 PM
awr68's Avatar
I say go with the 454 in TR and I will trade you my blower ready LT1 for the 5.3!
Tony
'68 Camaro
