Old 06-24-2010, 12:37 PM
danksta69Z danksta69Z is offline
Default difference between L92 and LS3
Ya was just wondering what is the differance between a L92 and a LS3 engine?
Old 06-24-2010, 01:05 PM
Heavier valves in the L92 and milder more torque cam for a truck in the L92.
Frank Serafine
Old 06-24-2010, 01:20 PM
wiedemab's Avatar
wiedemab wiedemab is offline
I could be wrong, but isn't the L92 VVT and the LS3 not.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 06-24-2010, 02:48 PM
And the VVT.
Frank Serafine
Old 06-24-2010, 09:47 PM
ivmotor ivmotor is offline
and extremities
Old 07-29-2010, 02:02 AM
SS1156's Avatar
SS1156 SS1156 is offline
Is the L92 easier to get used? Are there any differences in building up either of them? I was thinking of installing a L92 into this 70 Camaro if the deal goes through and was wondering how difficult the install will be. I planned on going through the L92 and going with a larger cam, nice set of heads and I really wanted to keep the EFI on it as well. Would it be easier to get an LS3 that already has decent HP and just install that? Sorry for all the questions, but I am trying to learn as much as I can.
SOLD 1993 Saleen Mustang #20 of 56, Black & Gold sittin on 17" Sterns.
FQuick: www.fquick.com/ss1156
*New car 1970 Camaro SS clone*
* Soon to be under construction*
Old 07-29-2010, 05:00 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Stock heads are great as is, add hardened push rods, car intake, ls7 cam, good valve springs, headers and you have 500 HP.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 07-29-2010, 06:38 AM
71RS/SS396's Avatar
As stated the L-92 heads are great as is, but if it's an 07 change the valves they had problems with the stock valves breaking that year. Check with Mast Motorsports from cams/limiters to take advantage of the VVT.
Old 07-29-2010, 07:10 AM
On street motors unnder 420" I like the stock heads better then worked heads.
Frank Serafine
Old 08-01-2010, 08:42 AM
Pantera EFI Pantera EFI is offline
Default L-92 = Ok
We have sold our ECU-882C-1 to WaterThunder.com for over 400 L-92 engines that Dave "refits" into Air Boats.
This is what I found:
The stock weight valves will "rev" to over 7000 RPM without breakage.
The Truck Intake is always changed to the LS-3 Corvette Intake.
The Valve Springs are always replaced with "yellow" springs OR "duals" when cam lift exceeds the "yellows" .580" safe lift.
When VVT is operational (pin lock disengaged) the Pantera EFI "limiter" is used to limit Retard/Advance.
(be aware, Comps will allow for FULL ADVANCE to 4 degree Advance ONLY)
The Fuel Injector size is increased in some cases.
The Reluctor to Crankshaft reference needs to be +1.75 to +1.50. (stock reference is retarded)
Safety dictates REMOVAL of the DBW throttle body electric motor with a DBC shaft.
Ignition timing needs to modest, in the 28 degree range.
Remember the L-92 has a HIGH VOLUME oil pump the can empty some "after market" oil pans.
Lance
