Old 06-24-2010, 05:58 PM
Default Wilwood D52 Calipers Are Here In Red And Black
Now in stock in Red and NOW available in Black also.
Only $350 a pair includes pads!
These Wilwood GM D52 calipers are direct 2-piston bolt-on replacements for the factory original single calipers on many 1968-96 GM passenger vehicles and trucks. They feature forged billet aluminum bodies, stainless steel pistons, and competition-style high-temperature seals. They put and end to the rust, bore pitting, and seal failures that plague the OE caliper design. The Wilwood GM D52 calipers provide low-maintenance performance and a huge weight savings with high-temperature reliability for the street and track. They mount in the stock location over stock rotors and use the original-style OE D52 brake pads and an OE banjo bolt brake line. The calipers can be used with most wheels that clear the OEM calipers. They include Wilwood's hardened slide pins.
Frank Serafine
Old 06-24-2010, 07:42 PM
tobenk tobenk is offline
Frank do u know if they fit a 88 chevy truck? Im trying to find brakes for the front of this truck thats not so outrageous.
Old 06-24-2010, 08:48 PM
They fit anything with the standard single piston factory calipers.
Frank Serafine
Old 06-24-2010, 09:23 PM
SLO_Z28 SLO_Z28 is offline
Good price on those.
Do you know if they will for a 614 pad?
Old 06-25-2010, 03:09 AM
I will find out
Frank Serafine
