Old 06-27-2010, 05:35 AM
427gt500E 427gt500E is offline
Default Jon Kaase built Boss 598 & JPT full rollerized C6 w/overdrive
Selling my project engine and transmission since I cannot use them anymore.I was having a custom 69 Mach 1 pro touring car built called Kama Kaase.Some of you may have seen the post on my build here.Anyway, the car will not be built since the builders are being investigated for serious fraud and felony charges and are now on the run.I have lost a total of $126,500.00 dollars and that does not include attorney fees.I'm just trying to recoupe some of my F'ing losses.
I'm selling my Kaase built 598ci Boss motor.The engine dyno'd at 1007hp and 829 torque.The engine is currently at Jon's shop.I paid 27k for the motor.If you need specs on the motor please call Cliff at John Kaase racing.This engine only has dyno time.Never been installed and is crated and ready to ship.All offers will be considered,just don't lowball me and waste my time please.Here is a video of the dyno....this is all on 92 octane pump gas.
Guys....this engine is no longer for sale by me or through Lateral G......if your interested in this engine you'll need to speak with JKR and work out the details with them.Thank you for your understanding....
https://www.youtube.com/watch?v=c-kgD0ZPsIc
Also selling my JPT fully rollerized C6 with overdrive installed.I paid 8k for this setup and will consider any offer as well.A bit of info on the trans.. $6000.
10 inch steel stator furnace brazed full torrington bearing race convertor.4k stall.
Billet input shaft
Lightened JPT billet drums
Custom sun shell
Alto race clutches
Kolee steel discs
Kevlar bands
Billet full manual JPT valve body
Hardened pump gears
Full roller throughout
Aluminum deep pan
Gear Vendors .067 overdrive unit installed
Dyno tested by JPT
Winters shifter kit
This engine and trans had the best of the best building it.The engineering that went into designing this combination to work perfectly together is just incredible.Would love to sell both the engine and trans together but I understand that may not be possible.I will not part anything out.
If nobody here is interested, please,if you would pass this on to people you may know who needs a badass engine and trans.Thank you
Old 06-27-2010, 05:38 AM
I'd like to sell the Mustang shell as well.The metal work is 80% finished.All it needs is the rear frame rails,rear floor and roof skin welded on.I have all those parts.The bodywork wouldn't take much as every piece of sheet metal is brand new.The car comes with a $9000.00 air ride system,Wilwood brakes,electric exhaust dump cut outs,Mustang ll susp is installed but not seen in pics. These assholes have the titlework all screwed up but my attorney is trying to get all that worked out.
If anyone has any idea how I can go about selling this entire package please let me know or perhaps you can tell other people about this.
$14000.
Old 06-27-2010, 05:41 AM
Engine..
Trans..
Old 06-27-2010, 05:44 AM
69 Mach 1 shell... $14000.
Old 06-27-2010, 01:11 PM
So in the other thread it sounded like you had the car in a shop that would finish it. Why not see it through? I assume your so disgruntled you would just assume it disappear?
If your going to bail I would list it as a package with all the cool parts you have. Sounds like a cool take over project for someone.
But I still think you should finish it.
Frank Serafine
Old 06-27-2010, 04:47 PM
FETorino's Avatar
FETorino FETorino is offline
Default Maybe the motor will sell here
It certainly is the ultimate 385 Lima
http://www.network54.com/Forum/651691/
Rob in SoCal
Old 06-27-2010, 04:49 PM
Frank,these ass holes took me for so much money and crushed my dreams,I don't even care anymore.I've been into cool Ford hotrods for 30 years and now I have no interest anymore.Yeah,I'm bitter but life goes on.When something like this happens to a person it's life changing.
Old 06-27-2010, 04:54 PM
4mm 4mm is offline
Only if it would fit in my 71 Boss Mustang.
Good luck with the sale.
Old 06-27-2010, 07:12 PM
FETorino's Avatar
Default Just some shock tower massaging
It will fit in there. Ford put these in 69 and 70 mustangs while retaining the shock towers. Although they were modified.
Rob in SoCal
