Old 06-27-2010, 11:08 AM
turbosonoma turbosonoma is offline
Default wilwood/tci question
so i order a tci pro touring front end and request the biggest brakes possible, that is 14" with the smaller 9.44" sl6r radial mount caliper, then i ordered brakes for the back to match the front, my options are 13 or 14", since the price difference is minimal i went for 14's, these come with a completely different 4 piston caliper that has the three round impressions on each side so youd think it is a 6 piston and its huge compared to the front one , like 1.5" longer and wider and bigger the other way to. so i cant exactly put completely looking bigger calipers on the back than the front, so what got messed up here? initially i told tci i wanted bigger front calipers as the sl6r looks very small against the 14" rotor, but they said thats the only one they can do, so must i downgrade rear brakes now or???
Old 06-27-2010, 12:14 PM
I do not know why TCI and other subframe and suspension companies use anything but the biggest calipers. i can think of another couple compaines that do (4) piston 13 and 14 inch kits?
To keep you brake kit schmetric (bigger front / smaller rear, you can go down to a 12.2 and we can add a Dynapro (6) caliper, this is not a Wilwood numbered kit, but something we can build for you.
Frank Serafine
Old 06-27-2010, 12:32 PM
well the whole object here is to keep things matching, i figured out its a w4a rear and a sl6r front.
Old 06-27-2010, 06:43 PM
So you can get a Superlite 4 for the rear to match. but it is a complete different kit.
Frank Serafine
Old 06-28-2010, 03:28 PM
slow4dr's Avatar
slow4dr slow4dr is offline
The Camaro stops just as good as many of the big dollar set-ups. That car finished in the 6th position at the RTTC speed/stop event with a 13" SL6 front and 13" SL4 rear set-up on it. Had that test not involved acceleration I'm sure we would have finished in the VERY top since our car is certainly slower 0-60 than the cars that finished ahead of us.
Now, some may want "the look" and I can understand that. Which is why I am having Wilwood send us these parts to test and design new brackets for. Unfortunately, for this customer that will not help in a timely manner since we are in the middle of other projects right now.
In case people are thinking we sell mismatched parts, the rear brake kit wasn't supplied by TCI.
-J
'04 IS300 LS3/TR6060 swap in process
'89 Plymouth Colt GT - 411WHP, 2490lbs & 32mpg
'06 Magnum SRT8 - AFE S2, 3" Flowmaster catback, Diablo Predator (KIA by a drunk driver 10-25-13)
63 Nova 'Low Budget G-Machine' *SOLD*
Old 06-28-2010, 06:59 PM
Based on his description it was not sounding like a Superlite. Superlite are more then enough in most cases. No idea where he got the monster w4a which is HUGE!
Frank Serafine
