Old 06-30-2010, 11:22 AM
68sixspeed's Avatar
68sixspeed 68sixspeed is offline
Default 427 small block, all aluminum, 623hp, pump gas
Time for me to join the "LS" motor cult... complete package for sale--
Full, complete 427 small block, 1600 street miles on it. (no track time) Best parts available.
Motown aluminum block, 4.130 bore
Callies crank, 4" stroke
Callies 6.00" rods
custom j&e flat top pistons with thermal coating on top, dry film lube on the sides
AFR 227 competition cnc'd heads with some hand cleanup work done to improve them. (2.1 intake valve, 1.6 exhaust) upgraded to isky springs, titanium spring retainers with steel locks
Jesel shaft rockers, 1.55/1.65 ratio (not the SS series, the more expensive ones!)
APS custom aluminum oil pan with trap door baffles - was in a first gen camaro
APS custom valve covers
Wilson ported edelbrock super victor intake
ATI balancer
HVH carb spacer
950cfm 4150hp series carb
MSD pro billet distributor
MSD 6AL ignition and coil
Custom moroso spark plug wires
Hooker super comp 1-7/8 headers, ceramic coated (1st gen camaro)
polished aluminum water pump
pulleys, alternator, alternator brackets
chrome energy suspensions motor mounts
holley fuel pump, fuel feed lines etc.
Runs on premium pump gas
dyno'd 623hp @ 6800, 557lb-ft torque @5400
Professionally built
Very streetable but make sure you have the wheels pointed straight if you are going to jump on the gas!
$12,950 with the items above but if you don't need the headers, msd, or something like that we can negotiate. If interested in a bigger package I also have a richmond 6 speed, clutch, flywheel, bell housing etc mated to this motor for $14.950
Asking price doesn't even cover the parts that are here, let alone the labor, dyno time etc. Only reason I'm selling is to change the car to a milder LS motor for street/track use.
68 Camaro RS/SS, Katech tweaked LS7/t56 magnum
68 Camaro RS Convertible Project
2006 Corvette Z06
2011 Corvette grand sport convertible
Old 06-30-2010, 01:23 PM
holmespine holmespine is offline
Default motor combo
I didn't think a richmond 6 speed could handle that much torque??? i thought its recomended max torque was 450... nice engine!!!
Old 06-30-2010, 01:57 PM
68sixspeed's Avatar
they tend to be a bit under-rated. Maybe leaving at the drag strip on full slicks with a 2-step set at 6k would be a problem, but as long as you don't dead hook them its good. Plus with a light motor the car is only 3150 lbs. thanks- Dan
2006 Corvette Z06
