Old 07-05-2010, 03:52 PM
g356gear's Avatar
g356gear g356gear is offline
Default Compact Replacement for stock brake booster?
Wondering of there is a more compact replacement for a stock power brake booster on a 69 Camaro. I want to clean up the engine bay a little more and this stock unit is taking up a lot of real estate with my BBC. Thanks.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 07-05-2010, 06:53 PM
Below is a Stainless Steel 8" Dual Diaphragm unit we use quite a bit. looks nice and clears tall Big block Valve covers.
Booster kit is $200, Chrome master, prop valve bracket adds $175
Frank Serafine
Old 07-05-2010, 07:08 PM
g356gear's Avatar
Can I use the fatbody master that I purchased from you for my Willwood rear discs Frank? Same bolt pattern and distance from the firewall as stock, or will I have to re-do all my brake lines?
Old 07-06-2010, 07:01 AM
Yes you can use your fat boy master. It is about 1" farther from the firewall and but you should be able to stretch the lines that little bit.
The booster is polished but can be scotch brighted for a brushed finish easy
Frank Serafine
