Old 07-08-2010, 04:14 PM
rallye455 rallye455 is offline
Default ??? About Wilwood Rear Parking Brake Kit
I have the Wilwood 140-7139 rear brake kit for my 9" Ford with Moser Axles. The axles have bolt in studs and the heads are hitting the Wilwood parking brake assembly. I assume the kit was designed for axles with press in studs. What has anyone done to correct this? I would hate to have to grind down the heads of the studs.
Old 07-09-2010, 07:52 AM
Apogee Apogee is offline
This type of interference certainly isn't unheard of, but only tends to be an issue when running screw-in type studs in the rear. From what I've seen, the Moser studs used to (and maybe still do) have the shortest heads compared to the other 1/2-20 screw-in options that I've seen (ARP, Wilwood, Moroso, etc). How much interference do you have? How much head on the wheel studs? If it just needs a small amount, I'd shave the heads of the studs to clear the parking brake components.
Tobin
KORE3
www.kore3.com
Old 07-23-2010, 09:19 PM
I ended up cutting down the heads. Fits fine now.
Old 07-24-2010, 02:53 AM
RGJZ06 RGJZ06 is offline
Sounds like I may have to do the same thing to mine. I a Wilwood disk/parking brake package like you do, (not sure of the part number), Moser Axles and nine inch rear end.
"Thanks for the heads up and the fix",
RGJZ06
