Old 07-12-2010, 10:39 AM
frankv11's Avatar
frankv11 frankv11 is offline
Default 2005 ctsv t56 swap
has any body out there used a t56 from ctsv for theyre swap. the t56 will be going in a 69 camaro. by what I can see I would have to eliminate shifter and out put (three prong).
1. will a standard t56 shifter fit
2. how do I change to yoke , do I have to change out put shaft or tail housing,
I have not even touched it yet but figure get as much info as possible before I do
Old 07-17-2010, 01:28 PM
frankv11's Avatar
so I assume nobody has used this type t56 for theyre swap.
Old 07-17-2010, 04:23 PM
SSMuscle SSMuscle is offline
I've been wondering this same thing since I have a 68 camaro that I'm swapping a 5.3 with a CTSV t56. Hopefully someone will chime in to answer both our questions
Old 07-18-2010, 01:35 AM
frankv11's Avatar
well I tell you what if I cant change the 3 prong yoke, I could just build a drive shaft that could mate to trans.
now the problem with that is what do you for the rear? because as far as I know U joints create a vibration that is cancelled out with the opposing U joint,( thats why they place u joints 90 degrees from eachother with opposing angles. ) but if I dont have 1 on trans out put shaft im almost sure ill get vibration at around 75mph-90mph
now if I can find a yoke that will mate to a 9" rear end from a 2010 camaro or cts v. may work. chances are slim.
so I guess build a custom yoke to fit rear end or viseversa (trans )
some body out there has to make a driveshaft conversion where both ends are ctsv style joionts ( euro style ) and different type yokes --- splines 27 etc....
Old 07-19-2010, 06:35 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
if i remember i'll look under the girlfriends cts-v when i get home and look. also yes you would have to change the output shaft on that trans because its a bolt on flange.
the new camaro uses the same design and i had to replace a drive shaft, fuel tank, front and rear flanges and all the bolts and the exhaust system because the 3 bolts that hold it on failed. i would rather have u joints than a rubber cuppler. something to think about.
Old 07-22-2010, 10:58 AM
CamaroAJ's Avatar
ok looking at the transmission i am going to say no. there is just too many things that would need to be changed to make it work. the shifter part is the main issue then the output shaft houseing and also the output shaft its self.
Old 07-22-2010, 04:32 PM
frankv11's Avatar
too late to backdown I bought italready , I called a few places. I will have to change the tail housing and mainshaft might as well upgrade to the viper shaft. as far as the shifter I looked at it yesterday, it seems like a pretty straight forward shifter so i'm confident it can work.
thanks for taking the time to look under the goat.
whats the reason for GM to use those driveshafts, maybe they needed to reduce vibration (if it was one piece ), but they are two piece front side being shorter than rear?
Old 07-22-2010, 04:33 PM
frankv11's Avatar
cts v (not goat) sorry
Old 12-22-2010, 09:23 PM
Zimm1000 Zimm1000 is offline
Default What Happened
I have a 56 chevy and just purchased a cts-v TR 6060 out of a 2004. I obviously ran into the same issues as you, which led me here. Just curious to know how this turned out for your project and if it was worth the cost, or if I should just sell the tranny, and get a more conventional one. Thanks, Zimm
Old 12-23-2010, 04:54 PM
PhillipM PhillipM is offline
Hate to break it to you... The T56 in the 2004 CTSV was NOT a TR6060. It was a standard T56. Just don't want you to think you have something you don't.
