Old 07-16-2010, 11:54 PM
sako sako is offline
Default front drum hubs for LS1 swap?
Hey guys, new here.
Im doing the LS1 front and back brake swap and cant find the front hubs for 69 camaro drum brakes.
Any sources?
Old 07-18-2010, 10:28 AM
LS1NOVA LS1NOVA is offline
You could start calling around to the big shops, they prob have some laying around.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 07-18-2010, 11:47 AM
Ponyracer Ponyracer is offline
flynbye performance sells the already modded with new studs for $125.
Old 07-19-2010, 12:56 PM
Apogee Apogee is offline
Originally Posted by sako View Post
Hey guys, new here.
Any sources?
If you want original cast steel drum hubs, all of the Chevy drum hubs from the 1964-1972 Chevelle/Camino, 1968-1974 Nova and 1967-1969 Camaro applications are the same. Note that the hubs used with a few of the 4-piston disc applications and BOP applications may differ.
If you buy used, be sure that the bearing counterbores are in good shape and tight on the races and that they don't have any cracks or wheel stud issues. If you buy some of the new imported hubs sold through many of the resto vendors...well the quality doesn't seem to be much better than used, so see above.
HTH,
Tobin
KORE3
www.kore3.com
