Old 07-19-2010, 05:06 PM
jkcamro67 jkcamro67 is offline
Default Keisler hydraulic clutch actuator
I put one of these kits in my 67 camaro with a 502 a tko 600. The kit works but the clutch pedal feels very stiff. Anyone experience this or have an idea what the problem could be?
Old 07-20-2010, 06:59 AM
KEISLERGENE's Avatar
KEISLERGENE KEISLERGENE is offline
Default Keisler Actuator
What hole did you put it in? Top or bottom? If you have a hard pedal it is usually a sign of pedal pushrod not going in straight.
Old 07-20-2010, 07:45 AM
I put in a complete kit from Keisler - 6 speed and the hydraulic clutch and it is an absolutely fabulous set up. The instructions were well written - the kit was complete to the last nut and bolt and the quality of the parts was top notch. We didn't have a single issue, so I think you may have "installation issues" with yours. Give 'em a call.
Old 07-20-2010, 08:20 PM
ill look at the hole it is installed in tomorrow. got to work on te reservoir too. It is leaking slightly whre the two plastic pieces come together
Old 07-21-2010, 11:39 AM
it is in the bottom hole of the two options
