Old 07-21-2010, 10:39 AM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Default SBC Block Question
I am building a 355 for my 68 camaro. I found a complete running 4 bolt main,350 pulled from a 89 k5 blazer.
My question is what is the difference in between pre-86 SBC and the 87-95?
I have a rotating assembly from a buddy for next to nothing already, minus the pistons.
I was thinking about running a dart top end kit from summit(http://www.summitracing.com/parts/CM...89&prefilter=1)
I have worked on 350's in the passed they were all pre-86 motors, I just want to make sure there wasnt any changes that are going to throw a wrench in this build if there was any changes at all
Old 07-21-2010, 11:22 AM
camcojb camcojb is offline
in 86 they swapped to a 1 piece rear main seal. Crank is different than the earlier ones.
Old 07-22-2010, 05:14 AM
deuce_454's Avatar
you can get a 1 piece rear seal adapter to run the new crank in an old block... but the other way will IIRC require mashining the crank.. not a big deal, and most machine shops can do it..
Jake: Hit it.
Old 07-22-2010, 10:48 PM
Thanks for the help. I think I clicked on the first 40-50 google links as well
