Old 07-22-2010, 12:26 PM
Default C5R racing engine
I'm posting this for a friend of mine. Yes this is legit. Yes this really came out of a LeMans C5R Pratt and Miller racecar.
THIS IS A USED FIA GT1-SPEC CORVETTE C5-R RACE ENGINE. OVER $85,000 NEW AS SHOWN
4000 RACE MILES SINCE LAST REBUILD
9000 MILES TOTAL ON BLOCK/HEADS
425 CUBIC INCHES
4.120 BORE
3.985 STROKE
12.5:1 COMPRESSION RATIO
C5-R RACE BLOCK (NOT GMPP BLOCK - NO LINERS - NIKASIL-COATED BORES) - HOT HONED WITH DECK PLATES
CNC-PORTED C5-R ALUMINUM RACE HEADS WITH BRONZE VALVE GUIDES AND COPPER BERRYLIUM
DEL WEST TITANIUM INTAKE AND EXHAUST VALVES 2.180"/1.625"
MAHLE 2618 FORGED ALUMINUM PISTONS
BRYANT FORGED STEEL CRANKSHAFT
CROWER H-BEAM BILLET TITANIUM CONNECTING RODS
KATECH C5-R TIMING CHAIN
LSM SOLID ROLLER CAMSHAFT
JESEL 1.7:1 ROLLER ROCKERS
JESEL .937" SOLID ROLLER LIFTERS
AUTO VERDI 5 STAGE DRY SUMP PUMP (4 SCAVENGE, 1 PRESSURE)
KATECH BILLET ALUMINUM OIL PAN
KATECH CROSS-RAM CARBON FIBER INDIVIDUAL RUNNER INTAKE MANIFOLD - 8 INDIVIDUAL THROTTLE BODIES
KATECH CARBON FIBER AIRBOX TRAY
KATECH ALUMINUM A-PLATE
KATECH C5-R CARBON FIBER VALVE COVERS
KATECH MODIFIED LS1 ALUMINUM WATER PUMP
BOSCH IGNITION SYSTEM
ATI DAMPER
RECENTLY VALIDATED ON THE ENGINE DYNAMOMETER
552HP RESTRICTED THROUGH 2 31.2MM RESTRICTORS
596FT-LBS OF TORQUE
CAN EASILY BE CONVERTED TO 700HP+ UNRESTRICTED
PAYMENT/SHIPPING-
-SHIPS VIA TRUCK FREIGHT. WINNER PAYS FREIGHT AND CRATING CHARGES. OR LOCAL PICKUP IN CLINTON TOWNSHIP MICHIGAN.
-PAYMENT VIA CERTIFIED CHECK, WIRE TRANSFER, OR CASH. NO PAYPAL
$25,000.00
You can contact me directly with questions and I will answer all questions as well as handle the transaction.
Tyler
Old 07-22-2010, 12:45 PM
Jr's Avatar
Jr Jr is offline
Tyler,
Sweet motor.
Where is the power steering pump?
Old 07-22-2010, 12:58 PM
It's not included, nor is the alternator, or Bosch ECU.
Tyler
Old 07-22-2010, 03:18 PM
War's Avatar
War War is offline
I think this is just what Dave needs in his car to go with those HRE's he's going to buy. He can still return that bling oil pan right.
Jason
Old 07-22-2010, 03:55 PM
coolwelder62's Avatar
WOW!!! that's the perfect motor for my Sunoco camaro.The bad thing I would have to sell the camaro to aford the motor.Good luck w/ the sale.
Old 07-22-2010, 05:04 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Does it come with an AC compressor?
Can't believe you aren't keeping this for project 50/50.
Doug
Old 07-22-2010, 05:27 PM
ironworks's Avatar
Doug
That's why he said he is posting for a friend.....
Old 07-22-2010, 06:19 PM
Doug
Come on BroMontana. Brosef. If this was something I owned don't you think I'd be pimping this on every thread known to man?
I'd be all like- "Those brakes are super sweet on your car; did you know that I have a C5R race engine?"
I'd win the whole internet if I had this engine. The entire thing. Mine. I'd share some of my newly won internets with Al Gore, since he invented it.
Tyler
Old 07-22-2010, 06:27 PM
Fluid Power's Avatar
At the risk of sounding stupid, How would you run this thing without the Bosch ECU?
Darren
Old 07-22-2010, 06:38 PM
Darren
Great question. Because this is a C5R and not a C6R engine, the sensors started out as factory type; then as the program evolved they would replace sensors from the racing line of Bosch until it was all all aftermarket. The only exception to this is the TPS on the carbon intake; it was never factory to begin with and would more than likely require a bracket fabricated to make a factory sensor adapt. Or you could run a MoTeC system.
Regardless, this thing runs on 114 octane, made from the souls of children. The fuel cell is really high tech and uses magic.
Kidding.
Tyler
