Old 07-23-2010, 01:26 PM
RBR's Avatar
RBR RBR is offline
Default gm flywheel # 14091599N
I was given this flywheel to use with my LQ9 motor. Can anyone help me to ID this flywheel? Can it be used with my motor?
Old 07-23-2010, 02:50 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I cross referenced the number on a couple of GM parts sites and nothing was found. I don't think it is a GM number. If it is a part for GM models it may be an aftermarket # and not a original GM #. But, GM has been known to change part numbers on parts that are still being used/produced.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-23-2010, 04:21 PM
RBR's Avatar
RBR RBR is offline
Thanks for looking for me I keep searching. What if the number of teeth and the bolt holes are the same as the flex plate? Is that a good sign it might work?
Old 07-23-2010, 05:24 PM
214Chevy's Avatar
Logically it sounds right. But, I think there are other variable in the equation that may not work in the long run. Such as, thickness of the flywheel, spacing of the flywheel, etc.
'68 C10 swb
'72 Chevelle
Old 07-24-2010, 11:43 AM
RBR's Avatar
RBR RBR is offline
I was really hoping someone would say "yep that will work"! thanks for the reply
