it will work great when the tank is full... (external fuel pumps are a bit more noisy.. but with a nice exhause, who cares) but when you are down to the last 3 gallons it will cut out in long corners.. fuel will slosh away from the pickup and you will loose fuel pressure and the engine will cut out immediately.. then when you are outr of the corner it will spring back to life...
so yes it will work.. but not well when not full
Jake: Hit it.
