Old 07-25-2010, 07:31 PM
rallye455 rallye455 is offline
Default How close can brake lines be to headers?
How close is acceptable for the hard brake lines to be near the headers? I know they should be as far away as possible but I just want to make sure they are far enough away to prevent problems in the future but dont have alot of room to reroute them.
Old 07-26-2010, 12:57 PM
Apogee Apogee is offline
Anything less than a couple of inches and there is ample reason for concern. If the headers are ceramic coated or wrapped, then you can easily be quite close without (m)any issues with the headers being the direct cause, however the cooler the better when it comes to brake fluid. How close are you?
Tobin
KORE3
www.kore3.com
Old 07-26-2010, 03:22 PM
Without completely redoing the line the most I could possibly get is 1/2".
Old 07-26-2010, 05:25 PM
Can you make some sort of thin sheet metal heat-shield? If so, that's going to be your best bet in that sort of situation. Stainless steel has a lower heat transfer coefficient and would be preferable over steel or aluminum, however anything would be better than what you've got now. Ceramic header coatings are decent at keeping the heat inside the headers and out of the engine compartments, so that's something to consider as well if your headers have something other than a thermal barrier coating.
In a pinch, aluminum HVAC tape can work as a decent reflective heat barrier when the primary mode of heat transfer is radiation. It just doesn't tend to stay in place long enough to be considered a permanent type of solution.
Tobin
KORE3
www.kore3.com
Old 07-27-2010, 05:06 PM
what about covering the brake line with a cover such as those from heatshieldproducts
Old 07-28-2010, 07:41 AM
They have several products I would consider depending on whether you're hoping to shield the brake line or wrap the headers or both. Post up what you end up using and how well it works for you if you don't mind as this seems to come up every once in a while.
Tobin
KORE3
www.kore3.com
Old 07-28-2010, 08:20 AM
parsonsj parsonsj is offline
The most you can get is 1/2"? I think you should be planning on re-doing the line. Heat shields and the like can help, but 1/2" is just always going to be a problem.
jp
John Parsons
Old 07-28-2010, 09:55 PM
REDO it then...
Old 07-29-2010, 07:18 AM
This is one of thos "If you have to ask you already know the answer"
Frank Serafine
