Old 07-26-2010, 07:20 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Default New Vintage introduces New Performance Line instruments
New Vintage is finally announcing the release of the new Performance line of instruments.
The 6 gauge kits come in standard 5” and 3-3/8” speedo and tachs with 2-1/16” fuel, volts, temp and pressure. Each kit includes a matching GM style 0-90 ohm fuel sender or s standard 240-33 gauge with matching adjustable sender.
Each kit includes everything to install including a GM speedo sender.
These kits will be rolling out over the coming weeks. Why pay more for less? The competition expects you to.
These sets are made 100% in the USA and feature:
Glass, lens-No scratch able plastic
Titanium bezels
Easy-plug Packard connectors with color-coded harness for simple wiring
Full electronic, air-core movement
Push-to-calibrate function. Push a button , drive a mile, push it again, and you’re done! No DIP switches or calculations.
Hourmeter: Really know how many hours your engine has been running with the hour meter function. Just install a ground-on switch
As always, our gauge kits include EVERYTHING required to install:
Sealed Packard connectors with 12” of color-coded wiring where required
GM style electronic speedometer sender
Momentary push button switch
Detailed, clear instructions
Oil pressure sending unit
Water temperature sending unit
Fuel level sending unit-standard--OR GM fuel gauge
Mounting hardware
Sender bushings
Why stop there, New Vintage also does custom work, why not ask about custom dials, lighting, whatever you need.
Enough of the talk, here are some pics:
3-3/8" kits:
5" kits:
Thanks for looking
Mark
www.newvintageusa.com
Old 07-27-2010, 04:56 AM
meenaggie meenaggie is offline
Do you have any pictures of what they would look like at night? Thanks in advance.
Old 07-27-2010, 05:25 AM
marks914's Avatar
Regular User
These are normal perimiter lit gauges, Ill take some pics tonight and post them
FYI the 3-3/8 sets are $425 and the 5" kits are $459 thurough 8/15
Mark
Old 07-27-2010, 12:06 PM
wellis77's Avatar
wellis77 wellis77 is offline
What kind of additional cost to do custom dials, lighting, etc?
Old 07-27-2010, 02:45 PM
marks914's Avatar
Regular User
It really depends, but printing metal dials runs about $195 and design time is $85.00 per hour as needed, so you can get into a custom set for $750-$900 depending on what is involved.
We can use LED bulbs, or strips. Custom backlit gauges too.
Mark
Old 07-29-2010, 06:55 PM
marks914's Avatar
Regular User
As requested, here are some pics of the gauges lit at night
Mark
Old 08-01-2010, 12:56 AM
Thanks for posting the additional pictures. Looks like a good value. I still have my eyes on your full sweep, back-lit guages.
Old 08-19-2010, 05:07 AM
marks914's Avatar
Regular User
FYI,
I have all of the colors and sizes on order, should have everything in a few weeks.
Right now we have white in stock, both 5" and 3-3/8 speedos/tachs
We are running a special until 8/29, any lateral-g.net member can recieve 10% off, just email us with your lateral-g handle and we will email you a promo cosde good for 24 hours.
Ill post this in its own post this weekend.
Mark
Old 10-18-2010, 06:13 AM
marks914's Avatar
Regular User
FYI- we have everything for the performance line in stock, ready to ship. We are currently offering all lateral-g members 10% off all in-stock items and 15% off any custom work.
As always, our kits come complete with everything to install, even a GM speedometer sender! and MADE IN THE USA with our 5 year warranty!
Mark
Old 10-18-2010, 07:07 AM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
Looks really good i like the simple styles
A man that's motivated will find a way.
PROJECT'S
1984 GMC swb truck
1972 Camaro
2013 GMC truck
