Old 12-22-2005, 10:58 AM
rwhite692's Avatar
Default Disassembly for hi-temp coating?
Hi Jason,
I'm about to get my manifolds and housings high temp coated.
I would like to know if there are any special considerations or instructions for disassembly of the turbos. It looks very straightforward, but figured I should ask first. If OK to disassemble, what are the torque specs for re-assembly?
If there is a lot of associated complexity/risk, or will put me SOL if there is a problem with the units later down the road, then I won't bother, and will just do my manifolds.
Also...shouldn't the bolts on the turbo housings be set up for safety wire?
Thanks,
Rob
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 12-22-2005, 12:20 PM
slow4dr's Avatar
slow4dr slow4dr is offline
Originally Posted by rwhite692
Hi Jason,
Thanks,
Rob
Safety wiring isn't necessary.
Break the 6 bolts loose on the turbine housing. Place the turbos compressor inlet face down on a nice flat bench area. You can do it with the compressor side facing up also. Finish removing all 6 bolts and accompanying 3 mounting plates. Then just lift the turbine housing off being careful not damage the turbine wheel. Reverse steps for puting it back together.
12-15 ft-lbs
'04 IS300 LS3/TR6060 swap in process
'89 Plymouth Colt GT - 411WHP, 2490lbs & 32mpg
'06 Magnum SRT8 - AFE S2, 3" Flowmaster catback, Diablo Predator (KIA by a drunk driver 10-25-13)
63 Nova 'Low Budget G-Machine' *SOLD*
Old 12-22-2005, 01:41 PM
rwhite692's Avatar
Thanks Jason for the quick reply! -Rob
My Lateral-G Page
My Shop Build:
Old 12-22-2005, 03:12 PM
slow4dr's Avatar
I wanna see pics after they're coated.
Old 12-22-2005, 04:18 PM
rwhite692's Avatar
Jason, I will post pics...Scott already had his done, I think.
I'm going with a matte black coating so...they won't look (in photos) much different than parts sprayed with BBQ black paint!!
My Lateral-G Page
My Shop Build:
