Old 08-01-2010, 12:16 PM
speedshftr speedshftr is offline
Default can tranny coller lines from powerglide be used on 350th
i switched from powerglide and went to a turbo 350.can the tranny lines be reused with mods or should i just make a new set?car is e68 camaro
Old 08-02-2010, 09:31 PM
sikryd sikryd is offline
Are you talking about the cooler lines? I don't see why you could not reuse the existing lines. do these go to the radiator to cool the fluid, or an axillary cooler? Only issue I would see is if the line size is different than the lines on the 350. Hope this helps, but just my .02...
