Old 08-04-2010, 06:43 PM
sikryd sikryd is offline
Default Problem with DSE solid body mounts?
Has anyone run into any installation issues with the DSE solid body bushings? My body shop guy said that only the front firewall bushings will line up. I have not had a chance to get down there to see the problem myself, but wanted to check with you all to see if you have run into the same issue.
Old 08-04-2010, 08:20 PM
Installed dozens, no issue here.
Frank Serafine
Old 08-04-2010, 08:30 PM
I just got back from the body shop, and the rear hole from sub-frame to body seems to be about a 1/4" off. My theory is that because the car has sub-frame connectors welded in and the guy has the car on a lift, there is some undue stress on that area that may cause the holes to not line up. I asked him to put the car on the ground and try to fit them... Do you install your mounts with car on ground, or on a lift?
Old 08-04-2010, 09:33 PM
Musclerodz's Avatar
Have the front already been tightened with out lining up the frame? Never had an issue with them
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-04-2010, 10:09 PM
What would a mount have to do with a subframe and body alignment?
Old 08-04-2010, 10:27 PM
Musclerodz's Avatar
there is enough room for the sub too move with the front bushings in and the rear will not line up if not adjusted properly. If the alignment pins are lined up and the rear still not going in, the frame could be tweaked
Mike Redpath
facebook page
Old 08-04-2010, 10:31 PM
I still ask, what would a DSE solid body mount have to do with a misaligned subframe?
Old 08-04-2010, 11:07 PM
Musclerodz's Avatar
nothing
Mike Redpath
facebook page
Old 08-04-2010, 11:08 PM
Exactly....
Old 08-05-2010, 12:00 AM
Measured the frame and it's square... The bolts are in just a few threads in the front 4 mounts. I guess I have to wait and see if the rear ones line up with the car on the ground. Not sure whats causing it...
