Old 08-06-2010, 05:53 PM
Blake Foster's Avatar
Default Pilot brg for Viper t56 and LS
so this is a peice of cake conversion ............ rigth.
so the viper has a pilot shaft with a .750 diameter. the ls is like .560
any ideas on what pilot brg to use???
Blake Foster
www.speedtechperformance.com
Old 08-06-2010, 06:44 PM
1Bad68Cat 1Bad68Cat is offline
Is the LS pilot bearing a 2 piece design like Fords? I pressed the roller bearing part out on a 5.0L roller bearing and machined the outer case i.d. to accept the viper pilot bearing that way I didn't have to machine down the input shaft.
Old 08-07-2010, 09:58 AM
i will have a look thanks for the idea
Blake Foster
