Old 08-16-2010, 01:51 PM
cp72ss cp72ss is offline
Default Fixing texture on Dash
Hello,
I am finishing a 72 SS Chevelle and was wondering if anyone has fixed an original dash. On my existing SS dash there are a couple of holes that were drilled for aftermarket switches. These holes are not big but my concern is if i try to fill and sand the dash I will smooth it out and no longer have the original texture of the dash.
Any suggestions on how to fix the plastic but yet still retain or create the texture pattern in the plastic?
Any help would be appreciated.
thanks
Old 08-16-2010, 05:02 PM
jliddle jliddle is offline
SEM Texture Coating > http://www.yourautotrim.com/semteco.html
You can fix the hole as normal on any plastic surface. Then before applying the factory color coat, put a few coats of the Texture Coating on. Coarseness increases as your distance from the surface increases. Make sense?
Further away you get.. Rougher the texture.
Then just coat with a color coat to match the rest of the dash and your golden.
Old 08-16-2010, 06:07 PM
We have done a great job bondoing the holes and scribing the pattern into it. if you catch the bondo at just the right time, it is pretty easy with a sharp knife.
71' 72 dashes are pretty easy to find, same as Monte Carlos. 70 is the tuff one to find because of no Fasten Seat belt Light
Frank Serafine
Old 08-16-2010, 10:19 PM
Default Sweet
Thank you!
Ill give it a try and see how it turns out. Worse case ill have to buy a new shell :-) Gotta learn at some point.
thanks again
Chris
