Closed Thread
Old 08-18-2010, 09:05 AM
TopEndeR TopEndeR is offline
Post Fs: One Bad Camaro
1968 CAMARO SS WITH A BUILT 383 STROKER. THIS IS ONE BAD CAMARO WITH AROUND 550 HP (I HAVE ENGINE DYNO SHEETS) WITH A TH400 TRANS. THE MOTOR ALONE IS WORTH AROUND $12,000. IT HAS AFR 210CC HEADS ON IT. MOTOR HAS 10:75:1 COMPRESSION, CAM IS A XTREME ENERGY XR292R. HAS A FORGED LUNATI BOTTOM END. RUNS VERY COOL. HAS A 10 BOLT, MOSER AXLES AND 373 REAREND GEARS. READEND HAS SOME NOISE DUE TO INORRECT INSTALL OF PISTION DEPTH. BODY IS RUST FREE FLOOR PANS ARE LIKE NEW. HAS NEW INTERIOR AND NEW TIRES AND WHEELS. FLOMASTER EXH. GUYS IF YOU WANT A BAD STREET CAR THIS IS IT. I’VE SPENT A LOT OF TIME AND MONEY IN THIS CAR AND I PROMISE YOU WILL NOT BE DISSAPOINTED. ANY QUESTIONS CALL 716-206-4142. 25,000 O/B
Old 08-18-2010, 04:31 PM
motor alone is 12k?
Old 08-20-2010, 06:23 AM
130fe 130fe is offline
Topender, $25k for a car with rear end noise? Good luck with the sale. You could also try over at www.camaros.net
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 09-22-2010, 07:27 PM
ArisESQ ArisESQ is offline
Originally Posted by Mr.VENGEANCE View Post
motor alone is 12k?
i dunno, i believe that. price of quality parts ad up quick, even on small blocks. i recently added up the receipts for my relatively mild 350 and it came out to 8k pretty easily, and i was definitely on a budget.
Old 09-22-2010, 09:40 PM
awr68's Avatar
awr68 awr68 is offline
Originally Posted by ill steez View Post
i recently added up the receipts for my relatively mild 350.
You sir are way braver than I! I'm not ready to go there...not just yet! Especially with the price of LS motors getting so affordable I may really question my LT1 build!!
Tony
'68 Camaro
Old 09-22-2010, 10:54 PM
pavell's Avatar
pavell pavell is offline
wow; it looks like a nice go fast car!
Old 09-24-2010, 10:18 AM
thefreak's Avatar
thefreak thefreak is offline
Your ad would be a lot more attractive if you didn't type LIKE THIS! I'm sure it's a nice car but a lot of people will be turned off because of the way you typed your ad. I suggest you edit it and turn off the caps and you will get a better response.
Good luck with the sale and cool car.
Old 09-26-2010, 06:18 PM
Believe me, it was a mistake .
I was pretty set on selling the motor in the next couple months and putting together an LQ9, or maybe even a 5.3, but now I may just put my money elsewhere in the car and just hold off till I can justify the huge loss I'd take on the motor.
In any case, don't want to hi-jack! Good luck with the sale!
Closed Thread
