Old 08-23-2010, 02:05 PM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default C2/C3 Handling & Steering Package Steeroids and Van Steel
Its that time of year to be driving that Vette
Make it even more fun to drive with this great package we have put together for you
-Arms
2 QA1 Coilovers Shocks
2 Upper Shock Mounting Brackets
Spanner Wrenches
Complete With Ball Joints
Uppers
• 6 Degrees Positive Caster for Improved Highway Stability
• Light Weight, Super Strong Chromoly Steel Construction
• Delrin Bushings
• Gloss Black, Long Lasting Powder Coat Finish
• Pre-Assembled
• Van Steel Limited Life Time Warranty
Lowers
• Light Weight, Super Strong Tubular Chromoly Steel Construction
• Designed For the Semi-Coil Over Spring Conversion
• Delrin Bushings
• Pre-Assembled
Van Steel, an industry leader in Corvette Suspension and Brakes, has ready for delivery, light weight, front upper control arms for the 1963-82 Corvette. Realizing most Corvettes drive on radial tires, Van Steel has designed this arm with 6 degrees of positive caster for premium highway stability.
63-82 Tubular A-Arms W/Coilovers 450# Springs- Car Set
Corvette Steeroids - Feel The Road! Steeroids™
Offers Improved Steering Feel -
Recirculating ball steering is vague and unresponsive, especially "on center".
Control is greatly enhanced.
Steeroids Offers Quicker Ratio -Steering racks offer quicker ratios. Steeroids™ power kits yield approximately 2.5 turns lock-to-lock (~2.9 for manual).
Steeroids are the only kits with adjustable tie rod ends to prevent bump steer - keep your car grounded and avoid darty behavior by keeping your alignment (bump steer) curves in check.
Steeroids Are Lighter Weight -Compared to the stock steering system.
Steeroids Offer Bolt On Installation -Absolutely no welding, or drilling. Installs with basic hand tools in approximately 3 hours.
Stock Pump Used -Existing or readily available power steering pump and brackets can be used.
Steeroids Come As A Complete Kit -All necessary parts are included with the exception of the power steering pump.
Parts Included With Steeroids: Rack and pinion
Adapter brackets (powder coated black)
Adjustable tie rod ends (Self cleaning & lubricating, teflon lined).
U-joint assembly
Power steering hoses
Misc. fasteners (grade-8)
Corvette Steeroids for Small Block Installation 63-66 Corvette SB - Power
Bought individually you would spend $3095.99
We have combined these two great products in a great package
for $2795.95
shipped free in the lower US
Package also for BB
You must call us toll free or PM to order and mention Lateral-g
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
www.xplosiveperformance.com
