Old 08-28-2010, 02:38 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Default FS: Vintage Air LS1 compressor brackets F-body
I have a brand new Vintage Air Part # 141803-MCA and a used GM F-body stock compressor bracket with tensioner & idler pulley. For use with Sanden compressor on first gen camaro/firebird. Stock subframe needs to be notched to run this as it mounts low in the stock location. Wil not fit with my wayne due subframe. This may fit other aftermarket subframes depending on your motor plates, mounts, headers, engine position, etc. I cut a piece out of the GM bracket to clear the motor plates. I kept the cutout piece so it can be welded back in if need be. Vintage air brackets alone list for $95 on the website. Asking $75 for both.
[email protected]
