Old 08-29-2010, 08:12 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Default Scotch-Brite Roloc clean & strip discs
Can anyone get me a case price cheaper than 3Ms cost? Don't know how many I'll need but I have to strip a 49 Fleetline and a 78 Malibu from top to bottom. Any recommendations on what size/color to use?
Old 08-30-2010, 06:15 AM
GM Muscle's Avatar
Use aircraft stripper and razor scrapers to start with, then use 180 on d/a paper then come back with your rolloc discs and what not. Check out you local swap meets for cheap consumables like rolocs
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 08-30-2010, 08:06 AM
Musclerodz's Avatar
you definitely don't want to strip a car with those. Cost would be crazy. Chemically strip what you can, then clean up with with Rolocs. 3M are pricey, you can buy them cheaper through Brown tool online which are local to me, but they sell all over the world.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-30-2010, 09:10 AM
elitecustombody's Avatar
I get 30%+ off all 3M products through my local Sherwin Williams distributor.
I agree with guys above,Aircraft stripper will make the job alot cheaper and less chance of warping the metal
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 08-30-2010, 12:51 PM
CRCRFT78's Avatar
I should proofread my posts. I need to strip two cars and wanted to use some Roloc discs during the process along with using a DA. I just wondered if anyone could get me a better price on a case than what I've found online. And how many it usually takes during the stripping process.
Old 08-30-2010, 03:23 PM
post a part# ,I'll check my cost
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 08-30-2010, 09:26 PM
CRCRFT78's Avatar
Scotch-Brite™ Roloc™ TR Clean Strip XT Disc, 3 in x NH S XCS
Durable, rigid, long lasting. Aggressive, open-web disc for cleaning welds, removing rust and paint. Roloc™ TR attachment system. Mineral: Silicon Carbide Extra Coarse Color: Purple* MOS: 15,000 rpm
* The color purple is a trade mark of 3M.
Stock Number: 61500153509
UPC: 0-48011-30016-0
Old 08-31-2010, 07:26 AM
I need part # or know what grit,there is 24,36 and 50 grit, 15 discs per box,is one box enough for you?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 08-31-2010, 11:38 AM
317millhand 317millhand is offline
I used 10 of the purple clean n strip discs to completely strip several layers of desert baked on paint from my 67 chevelle. I used the 4.5 inch ones that go on an angle grinder. They may be pricy, but work excellent without warping the metal or digging into the metal like a DA will. Also no worries of chemicals seeping back out later down the road. (unlikely but it does happen) They did strip it somewhat smooth, so I scuffed the bare surface a little before shooting SPI's epoxy primer on my car. Here they are on 3m's site. Havent tried the Roloc ones, so I cant comment on that. I stripped the jams and such with a cheapo sandblaster.
http://www.shop3m.com/61500187564.html
