Old 09-07-2010, 06:41 PM
bearcat bearcat is offline
Default Door Handle Problem
69 Camaro, marquez design door panels, no binding on the inside.
When you open the door from the inside, the door handle doesn't snap back. You have to push on the handle to get it down.
Is this an adjustment issue? Are the latches bad? It is consistent on both sides.
Thanks for the input!
Old 09-07-2010, 09:19 PM
gearheadgarage's Avatar
gearheadgarage gearheadgarage is offline
We always run return springs back to the door sheetmetal to help pull the release mechanisms back to the correct rest position. Works better & gives a better feel.
Old 09-08-2010, 04:17 PM
Ditto that
Old 09-08-2010, 04:20 PM
thanks all!! working it
