Old 09-08-2010, 04:16 AM
jarvis's Avatar
jarvis jarvis is offline
Default marine blower
Hi folks, any one know if you can fit a marine procharger on a car? whats the difference?
Old 09-08-2010, 07:20 AM
kochevy67's Avatar
kochevy67 kochevy67 is offline
I would call procharger direct and ask them so you know for sure.
Old 09-08-2010, 09:23 AM
deuce_454's Avatar
yes you can... no difference appart from more durable finish on some marine blowers
Jake: Hit it.
Old 09-08-2010, 10:47 AM
Ron in SoCal's Avatar
I've done a couple of marine blower motors and agree w above. If I'm not mistaken, most blower applications (roots, screw, centrifigul) use the same unit for marine or automotive. Engine differences have to do with cams, valve selection (inconnel exhaust), wet exhaust, forged bottom ends, sealed accessories, etc...
Marine motors are set up like RV's going up a hill, little momentum beyond the motor's acceleration. Always on, lots of heat!
Ron in SoCal
69 Camaro in progress
Old 09-08-2010, 01:00 PM
jarvis's Avatar
thanks guys, any tips as to where to pick up the piping for the charge system?
Old 09-11-2010, 04:50 AM
deuce_454's Avatar
ebay...
Jake: Hit it.
Old 09-13-2010, 05:01 PM
64duece 64duece is offline
The marine specific blowers have different impeller blades designed for better efficiency at lower boost levels (5-10psi). I worked with Jim Summers from Procharger about 5yrs ago testing their units on the dyno. Also...the nomenclature is slightly different (M2 sized same as D1) and so on...
There are a variety of tubing suppliers. For aluminum we like the Vibrant Performance stuff. Super nice and polished. If a natural or your not worried about some "marks" in the tubing we usually source them from Raceparts Solutions or any aircraft tubing supplier.
Dennis
Moore Racecraft
