Old 09-10-2010, 07:10 PM
67ragtp 67ragtp is offline
Default grease inside fuse box connector
Does any one know the name of the grease used on the fuse box connector housings(under hood), that tar like brown stuff? Want to try and find it locally like napa. Just dont no who makes it or the name- Thanks Rich
Old 09-10-2010, 10:33 PM
Musclerodz's Avatar
should be clear, and is called di-electric grease
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-13-2010, 10:17 PM
Rich do you mean the stuff like they use around the tubes coming out of the A/C suitcase?
Old 09-14-2010, 08:02 AM
Wayne - Im not sure what the grease on the ac suitcase looks like. I have a tube of clear dielectric grease from dow corning. The reason I did not use it is the temperature rating on it goes up to 400 deg F but Ive seen it melt and run far below that temp. American autowire stuffs there fuse box connectors with this brown heavy grease but only in there factory fit line. The classic update harness connectors are shipped with no grease. So Ive been looking for this thick brown gook and wondering where they get it and who makes it, almost looks like old thick axle greese.
Rich
Old 09-14-2010, 09:02 AM
I have to wonder WHY you want this "gook" in the first place?? Personally there's no way I'd use any of that kind of stuff in a modern built car.
Just asking.
Old 09-14-2010, 09:07 AM
I miss read what you were looking for Mike was rite.
Old 09-14-2010, 10:32 AM
Just asking.
Here's my logic(sometimes twisted), The two big connectors on the outside(engine bay) of the fuse box are exposed to the elements. I pulled many of the circuits out of the engine harness side connector(lots of efi sensors). It now has lots of open spaces where water can easily get in. The dielectric grease seals it up and prevents corrosion. Just looking for a non melting dielectric grease, fairly common for this application. The old brown gook seems to really last. Im not sure how other company's or newer style fuse panels seal up the weather side of there fuse boxes can only tell you that the classic update harnesses from AAW do not have any sealer in them. Im thinking about some long haul trips eventually and Im sure there will be rain/water potentially in this area.
Rich
Old 09-14-2010, 11:40 AM
GM Muscle's Avatar
ive used the liquid electrical tape several times to fil in pins where wires were removed before.. worked fine for me.. i think i actaully bought it at lowes.
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 09-14-2010, 02:31 PM
ccracin's Avatar
ccracin ccracin is offline
Rich
AAW is a vendor here. Call them and I would think they could give you some info.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-14-2010, 09:02 PM
Wouldn't you install a blanking plug into those open holes ? I've seen the weatherpack style plugs. They should be available from the vendor/manufacture of the component. Contact AAW like Chad said
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
