Old 09-24-2010, 09:18 AM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Default What fluids do you use in your cars?
Just wondering what fluids (transmission, rearend, brake, power steering, oil, coolant) everyone uses in their daily drivers and musclecars.
Old 09-24-2010, 09:25 AM
Bryce Bryce is offline
mobil 1 in the DDs.
Amsoil in the falcon.
Amsoil gear and trans fluid in all cars.
Old 09-24-2010, 09:56 AM
Josh69 Josh69 is offline
Whatever the dealer puts in for the DD's, not worth my time to do oil changes.
For my Firebird:
Brad Penn oil
GM Synchromesh in the TKO
Wilwood brake fluid
Napa/Valvoline HD gear oil in the rear (Moser/Detroit TruTrac)
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 09-24-2010, 11:01 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Originally Posted by 5280/4 View Post
mobil 1 in the DDs.
+1, other then i don't have a thundercougerfalconbird
Old 09-24-2010, 04:33 PM
SLO_Z28 SLO_Z28 is offline
Royal Purple Engine oil
Ford heavy Duty brake Fluid PN C6AZ-19542-AA (one of the better kept secrets, it our performs most racing brake fluids, and is cheaper than most brands)
B+M Trickshift ATF (For power steering too)
AMS oil gear oil
For coolant I use ethylene glycol based coolants, which are pretty much impossible to find in a retail situation. Everything now is propylene glycol, and isnt nearly as good. Best place to find this stuff is places that sell tractor parts, just make sure the bottle lists ASTM D 5216. This is the "old" style coolant that kills people. For a newer engine you want propylene glycol, OAT, or HAOT coolants.
Old 09-24-2010, 10:11 PM
monza's Avatar
monza monza is offline
greasy old thread
https://lateral-g.net/forums/show...&highlight=oil
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 09-24-2010, 10:43 PM
89 RS's Avatar
89 RS 89 RS is offline
Royal Purple in Camaro.
Mobil 1 in daily drivers.
Corey
1989 Camaro RS
