Old 09-27-2010, 04:02 PM
dixierods dixierods is offline
Default 5.7 Hemi/Kenne Bell
Anybody on here built a 5.7 with a kenne bell. I'm going to put one in a 72 Dart just wanted some feedback
Old 09-28-2010, 09:06 AM
rjsjea's Avatar
rjsjea rjsjea is offline
If you have no luck here check on Lxforums.com.......some pretty serious 3g hemi's over there
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 09-28-2010, 08:14 PM
thanks i will check that out
Old 09-29-2010, 06:51 AM
When I was at Kenne Bell they had one on the dyno, pretty damn impressive. If you need one we are distributors.
Frank Serafine
Old 10-11-2010, 06:12 PM
novahollic's Avatar
novahollic novahollic is offline
as far as i'm aware, they only make them for the 6.1 heads. it will bolt up to the 5.7 heads, but you will need to do some port work to match them up.
unless you are running the '09 and newer "eagle" 5.7, which has the same intake port design as the 6.1.
or you could run 6.1 heads on an older 5.7 block, but you would need to watch your compression ratio, cause it will be around 11.3.
just some thoughts
