Old 09-27-2010, 06:55 PM
Steve1968LS2's Avatar
Default 460 RHS engine build.. dyno tomorrow.
Ok.. so a few days of machine work at Nelson Racing followed by three days of building and I'm dynoing the 460 RHS engine tomorrow at Westech Performance.
Any guesses?
The 454 made 650 there and this one should make a bit more due to the better heads and a slight bump in compression (11.5:1)
It was a very detailed build, we flowed the Mast heads and then modded the valves to give more flow in the low to mid range area.. should be a torquie sucker. We weren't going to the "killer magazine number" but instead stayed with a hyd cam with a rather mild profile (touch bigger than the one in the 454).
Old 09-27-2010, 07:20 PM
Depends on camshaft?
Frank Serafine
Old 09-27-2010, 07:21 PM
247/263 .624 lift on a 114 LSA (installed at 110.5)
Old 09-27-2010, 07:23 PM
ArisESQ ArisESQ is offline
I'll guess it makes around 680 to 690. Which is an absurd amount of n/a horsepower!
Super cool motor. Is it for penny??
Old 09-27-2010, 07:25 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
I'm going with 680
Autokraft
Old 09-27-2010, 07:41 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
In number terms...I'll say 700 hp. In word play...I'll say it'll fly like a bat out of hell!! By the way it is oh-so beautiful. May I ask, what cfm size throttle body are you using?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-27-2010, 07:57 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Originally Posted by Steve1968LS2 View Post
[OT]Out of curiosity are you still running the 21st Century headers? If so, you may run into issues with the oil filter adapter on the Autocraft pan. In my project, I had to make the output/input for the filter entirely within the adapter to get clearance for the number 7 tube on the headers. Take a look here for what I'm talking about: http://www.pro-touring.com/forum/sho...&postcount=108[/OT]
Old 09-27-2010, 08:45 PM
Because of the 114LC and worked heads, guess 670HP / 570TQ
Frank Serafine
Old 09-27-2010, 08:59 PM
Yep.. it's my "last" engine and it's been a long time in planning. although it might come out one more time for a revised oil pan I've been sketching and maybe to add the oil squirters.
But in all honesty.. this engine has all top shelf stuff.. no place to really improve.
Old 09-27-2010, 09:00 PM
You're torque is way low.. my 454 made 625 lb-ft
