Old 10-08-2010, 06:57 AM
AM.MSCL's Avatar
AM.MSCL AM.MSCL is offline
Default Battery Drain?
My 69 Firebird is now showing issues with battery drain if not started with in a couple of days.
When I got the car it sat for a week between startups, maybe a little longer.
Over the summer I added Vintage Air w/ 3 knob controller, March Serp Kit with 140 amp alt., Electric fan, AutoMeter electric gauges in a Covan's thunderdash, electric choke, blower motor removed, fixed the broken wire for the sending unit in the gas tank, a new power interstate battery; there is not stereo in the car now (factory AM radio did not work). No additional electrical stuff was added that was not already on the car.
We had been driving the car daily for 3-4 weeks after getting everything finished up. We then went on a vacation for about a week and the wife went to start the car one day and the battery was dead. When I get home i checked to make sure A/C was in the off position and lights were off.
I put the charger on the battery for about an hour and she fires right up so we then take her for a drive for a hour with the rpms around 3000 the entire time on the highway (had to go across town to pick up another car). This was Tuesday night and I kept checking the Volt gauge and made sure it was at the 14 mark.
So this morning I planning to take the bird to work and try to start the car and I get fast clicking with the dash lights flickering with the headlights off and A/C off.
I have a volt meter to try and find the drain but want to get suggestions of where to start?
Anyone had this issue after adding something to their car? What was the final issue/solution?
Ray
Old 10-08-2010, 02:42 PM
AM.MSCL's Avatar
I disconnected the negative battery cable from the battery and put a amp meter between the cable and post of the battery.
It showed .50 draw with a 20A setting on the dial.
Gave the battery a charge enough to fire right up and the volt gauge in the dash sat just above 14 while driving around; sitting idle at a light it dropped to 14.
Old 10-08-2010, 02:56 PM
Watch your amp draw --- pull fuse one by one until you find the circuit.
Sometimes it's in the door/courtesy light switches - then tend to get corroded...
Sometimes it's electronics that have "memory" demands. If you go into a new BMW showroom -- every car has a battery tender on 'em now.
But I'd start with trying to find the circuit using the fuse box to see if it's a "obvious" circuit causing the issue.
Old 10-08-2010, 04:32 PM
billetman's Avatar
billetman billetman is offline
Good advice. To add to the troubleshooting tech already noted,you could also check for loose or corroded battery cables,loose ground on engine,battery's specific gravity,solenoid and starter connections,starter and solenoid operation and any lights or devices that may be staying on improperly such as a glove box door light etc. Hope this helps.
Old 10-09-2010, 09:58 AM
AM.MSCL's Avatar
I found a ground source that some things were connect to. One of those things also happen to be 12 volt off the fuse box under the dash. Got that disconnected and now .02 amp draw at the neg battery post.
Old 10-09-2010, 11:39 AM
There ya go!
Old 10-09-2010, 02:55 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
What Greg said. I leave my battery disconnected, negative and positive.
Good luck!
