Old 10-12-2010, 08:08 AM
DRJDVM's '69's Avatar
Default Parking brake handle
Does anyone other than Lokar making a decent parking break handle? Not a big fan of their unit
I'm looking for something compact......... havent searched the junk yards yet, but yes, that is one option...
Old 10-12-2010, 08:17 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
under dash mount or trans tunnel mount?
Old 10-12-2010, 09:03 AM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
Ned try Gennie shifter. They are similar to lokar but I think they are a higher quality piece.
http://www.gennieshifter.com/hand-loline.php
Luke Mau
L & H Kustoms
Old 10-12-2010, 10:17 AM
Trans tunnel mount.....
With the Cuda, the tunnel is moved to the pass side about 1.5 inches, so there is a pretty big gap between the driver seat and tunnel.....I was hoping to actually squeeze it between the driver seat and the tunnel
Old 10-12-2010, 05:10 PM
ironworks's Avatar
I starting to sell a bracket that make installing a Lokar unit that much easier if you need. 20 bucks. Press broke laser cut nice piece.
I will post pics tomorrow.
Rodger
Old 10-12-2010, 05:13 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Post some pictures up I may need one.
But I would like to incorporate it into a center console also.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 10-12-2010, 05:21 PM
ironworks's Avatar
JPEG from Solidworks, I'm making ECU brackets and ISIS brackets and Ron Francis fuse panel brackets.
I will post a pic with the handle installed.
Old 10-12-2010, 05:29 PM
ironworks's Avatar
Old 10-12-2010, 08:10 PM
So Rodger....are you basically mounting the piece on top of the tunnel?
Do you have any installed pix?
I've never installed a Lokar unit before, but dont you typically have to run the lower part of the untitthrough the floor
I'd like to see the ISIS brackets too....
Old 10-12-2010, 10:05 PM
ironworks's Avatar
I plan to mount this bracket on the floor in front of the seat. Tucked up close. Out of sight out of mind. The customer is running a marquez interior and it has a 70 camaro console that would not go well with this bracket.
The Isis bracket is similar to these. It has long flange to cut to length. These parts are just to make you life easier and quicker. Nothing is just bolt in. But If I can save you 4 hours in the garage with a 25 dollar part. That what I'm trying to do, just sell the parts we use over and over to make everyone's life easier. We will have bracket for FAST ECU's and anything else somebody needs.
Rodger
