11.6" Rear PBR disc upgrade kit
This kit is an OE upgrade for your '89 and earlier disc car or rear drum brake equipped car. Kit is complete and includes: loaded PBR caliper set, Raybestos/Delco rear rotors, new disc backing plates, new emergency brake cable set, new axle hard line set (2), new braided flex line set (3), new GM aluminum disc proportioning valve, brake line tabs and clips, all installation hardware, and an install guide to help you through it.
Item #3GPBR1
http://flynbye.com/catalog/i10.html
Important Notes:
The kit I have for sale has the following upgrades:
- NEW (not rebuilt) PBR calipers
- Zinc-washed rotors
- Stainless hard lines
The kit I have for sale does NOT include a prop valve or backing plates. I was planning to use the kit on an aftermarket rearend and was undecided on front brake setup, so I didn't order these parts. You will need to supply these parts specific to your combo.
I paid $800 for this kit when I purchased from Ed. The parts have never been out of the box.
Avoid the backlog and save some money too. Asking $650 + shipping.
