Old 10-18-2010, 09:58 AM
exwestracer's Avatar
exwestracer exwestracer is offline
Default Corvette ZF 6 speed throwout bearing...DEFINITE answer????
I've searched around and found a lot of different info on a hyd. throwout bearing for the Corvette ZF 6 speed manual trans.
Anyone done this or know of a place where I can get a definite answer as to which one works and how to install it? If I had a buck for every dead thread and different answer I've found, I could buy a T56...
It's a school project (turbo SBC and 6 speed in a Dodge Magnum) so we're going to use it. I'm just hoping to cut out some of the trial and error...
Thanks in advance
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 11-05-2010, 11:57 AM
1 Dwn Cam's Avatar
1 Dwn Cam 1 Dwn Cam is offline
Thanks in advance
McLeod Racing makes a internal Hyd Bearing for the ZF 6 Speed P/N 1345.
http://www.mcleodracing.com/products...mcl?rsku=17204
This will give you an Idea.
http://www.cardomain.com/ride/2368130/1
Vrbancic Brothers Procharged 406
781.5 HP @ 6500
701 @ 5500
14 psi.
Old 11-08-2010, 09:36 AM
steinepstein steinepstein is offline
Rockland gear is the source for the ZF 6 speeds.
zfdoc.com is also another great resource.
Old 11-08-2010, 04:04 PM
Thanks. Some good info there, but not what I needed to know.
1 Dwn Cam: I should have mentioned I'm converting to a PUSH type clutch. My mistake.
I'm looking at going with a QM or Tilton triple disc and univesal hyd. TO bearing. I have NO clutch parts from the Vette, so all in all it looks like that might be the cheapest route...
Old 11-08-2010, 08:22 PM
funcars funcars is offline
The stock C4 hydraulic slave cylinders (and clutch masters too) had lots of issues anyway so something else is preferable.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
