Old 10-18-2010, 09:32 PM
David Pozzi's Avatar
Default Power Performance Motorsports 2nd gen Camaro tall ball joints review
I just finished a test of .5" taller upper and lower ball joints. These are made by Power Performance Motorsports for 2nd gen Camaro/Firebird.
They make impressive gains in neg camber, the upper being the most beneficial with very low impact on bumpsteer. The tall lowers add a little more, but bumpsteer is worse. The 2nd gen steering linkage can be moved around quite a bit to improve bumpteer and even with tall upper and lower balljoints our early runs with the test car do not produce any noticeable steering feel problems.
David
Link:
http://www.pozziracing.com/second_ge...o_tall_bal.htm
Chart:
http://www.PozziRacing.com
Old 10-18-2010, 09:37 PM
Track Junky's Avatar
Dave, do you happen to have a similar chart for first gen's? Do you know if the Global West UCA's came with a longer ball joint?
Gaetano Cosentino
Old 10-19-2010, 09:10 PM
RAnthony97 RAnthony97 is offline
Here are test results for 1st Gen using tall ball joints.
http://www.pozziracing.com/power_performance_motorspo.htm
Old 10-19-2010, 09:14 PM
Gracias!!
Gaetano Cosentino
Old 10-21-2010, 07:30 AM
syborg tt's Avatar
Hi Dave,
Would these be something i should consider using with my new Ride-Tech suspension.
ps - yes it's on my 70 camaro project / not the little s10
marty-mj
