Old 10-22-2010, 09:20 AM
Blake Foster's Avatar
Default Comp Cams LS Double roller chain
so any body want to lay a bet if the Comp Cams Double Roller timing chain will fit a LS motor???
Answer NO! the 1/8 spacers for the oil pump are EXACTLY 1/16 of an inch too Thick? the oil pump hits the timing cover.
so just know you are making your own spacers, no big deal.
and you CANT use a high volumn pump only the stock pump.
FYI
Blake Foster
www.speedtechperformance.com
