Old 10-27-2010, 04:15 PM
Default 3/8" door wire looms big enough for power window harness??
I'm looking at a set of door wire looms to run my power window wires through. I found a stainless set with a 3/8" ID. Is that the ID everyone uses? I saw a set with 1/4" Thats got to be too small. Any help is appreciated.
Old 10-27-2010, 04:34 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Alot of cars go with that, But be thinking about adding in wires later on. See if there is a next size up, Better to have a little extra space than not enuf
TRACY WEAVER
www.recoveryroominteriors.com
Old 10-27-2010, 06:08 PM
Wayne ---
If I was to do it over again -- I'd use the multipoint contacts in the doors... and not run any wires.
Like the Magnum Shooters (just one brand...)
http://www.dakotadigital.com/index.c...103/prd103.htm
If not that -- the best ones I've found are the 5/8" looms that use a stainless steel SPRING wound loom. Like these:
http://gemstreetrods.com/body_-_door...m_aluminum.jpg
The braided hose versions "chafe" --- and the black plastic versions are just cheap crap. Just MHO.
Old 10-27-2010, 06:14 PM
If you're going BRAIDED loom ---
THIS - which has a nylon swivel to ease that chafe problem
http://www.summitracing.com/parts/ELI-94202/?rtype=10
Is FAR BETTER than this version:
http://www.summitracing.com/parts/HFM-DLOOMBL/?rtype=10
The aluminum door insert portion has sharp edges and the braided hose is like 80 grit! Remember that these have to move and in an arc -- and the braided hose wants to straighten out not arc! YUCK and NASTY....
Old 10-27-2010, 06:24 PM
MODO Innovations's Avatar
X2.
If you add power door locks, such as our keyless entry kit, you will add 2 more wire for each door. Other kits use a 5 wire actuator.
Shannon
Modo Innovations
940-391-9002
Old 10-27-2010, 07:31 PM
Thanks I had never seen some of those before.
Old 10-27-2010, 07:37 PM
You're welcome!
Old 10-27-2010, 10:33 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
When I put power into my 69's doors years ago, I went to the junkyard and opened a bunch of car doors until I saw some stock rubber boots that I liked.
I just drilled out my doors and jambs, inserted the boots, and now it looks like they came that way from the factory.
TJ Ragucci
http://www.northeastrodrun.com/
