Old 11-01-2010, 05:32 PM
1Bad68Cat 1Bad68Cat is offline
Question GM Truck 12 Bolt rebuild
Can anyone recommend a shop to rebuild the 12 bolt in my 66 c10 in southern California. A little surprised, Currie says they do not work on truck 12 bolts. I'm going to order Moser housing ends to use Ford 9" axle bearings and eliminate the c-clips. It suppose to allow me to use the factory brakes. I plan on going to 3.08 gears and posi because of the gearing in the 6L90 I'm putting in. Currently the truck has 4.11s and an open diff.
Thanks in advance
Robert
