Old 11-04-2010, 06:13 PM
wedged wedged is offline
Default custom Dana 60 what axle bearings to use ?
I'm building a custom width Dana 60 and can't decide what ends and bearing to use. It has to be pressed on bearings that do not need adjusters and cannot be a full floater. I want to make sure what I use will hold up well to side loads. Big Ford ? New ? Old ? Set 20 ? Sealed ?
This is for my '41 : build thread
Old 11-04-2010, 07:05 PM
Top Fuel Tom's Avatar
Top Fuel Tom Top Fuel Tom is offline
Strange engineering makes ends that use the 3.150 big bearings and retain the mopar bolt pattern if you want to use Mopar brakes. If you are going with an aftermarket brake package any of the big bearing ends will work.
www.hotrodbuilders.com
Old 11-05-2010, 06:44 AM
I got info last night on a caliper bracket kit I might use to mount the Ford Cobra calipers. I'll need to use a big ford end with the 3.150" bearing. The question still remains- which specific bearing is going to hold up best to side loads ?
Old 11-05-2010, 03:10 PM
FWIW, I'm going with Set 20 tapered bearings.
Old 11-05-2010, 05:05 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Set 20 also, its a tapered bearing.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
