Old 11-09-2010, 11:29 AM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Default What exactly is 2K urethane?
Hey Guys-
What exactly is 2K urethane and is it better than other types of coatings? Thanks!
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 11-10-2010, 09:35 AM
elitecustombody's Avatar
2k is 2-part component system which crosslinks in curing process and gives a solid base for top coats.
As far as what's better,it's more like what you're comfortable using according to your budget. There are many 2K primers on the market as well as hybrid primers,polyester primers and they all work great, just try to stay away from cheap no-name stuff,
I've always had great results from Evercoat Slick-Sand and FeatherfillG2 both are polyester high-build primers and at $40-60 per gallon is impossible to beat. For flexible parts and high impact areas I use Sherwin Williams P30 2K primer, it is very flexible,has amazing adhesion properties and sands easy like nothing else ,it also comes in different colors like red,black,yellow,green,blue and grey,which helps if you ever get chips,this primer is also can be easily converted to sealer.It costs about $300 gallon,plus you'll need hardener and reducer and converter if you want to make it into sealer.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
