Old 11-09-2010, 04:59 PM
tuff57 tuff57 is offline
Default New Barry Grant fuel filter, new billet specialties bbc alt bracket f/s
Brand New Barry Grant Part Number 170018
Lifted from Jegs
The BG5000 fuel filter with replaceable filter element is now lighter and more compact than ever. With threaded end caps, it is also more easily serviced and filters to 8-microns with virtually no loss in flow-volume - not even when used in conjunction with the super-high volume fuel pumps. The filter can be used with gasoline, alcohol or nitro with positive O-Ring sealing. Replaceable elements and O-Rings are available separately. Uses 1/2'' NPT inlet and outlet fittings.
$75
Brand New Low Mount Alternator Bracket For a Big Block Chevy
Part Number- FM0205PC
Lifted From Billet's website
Genuine Billet Specialties style, quality, fit and finish are engineered into our serpentine conversion kits. All brackets and pulleys are machined from 6061-T6 billet aluminum & polished to a mirror finish. Designed to bolt right on and align correctly the first time.
Application:
• Big Block Chevy
For use with
• GM 60 to 80 amp alternators (Driver Side)
• Standard rotation short water pumps
Kit Includes:
• Polished billet aluminum low mount alternator bracket
• Polished stainless steel turnbuckles
• Stainless steel mounting hardware
$100
My Build Thread:
https://lateral-g.net/forums/showthread.php4?t=25644
Sponsored by Prodigy Customs
Rick's Hot Rod Shop
Anvil Auto
