Old 11-11-2010, 06:10 PM
ironworks's Avatar
Default Ironworks Bring No brainer products to market for the Home builder.
Well after enough phone calls from you guys here on LAt-g for some of the slick brackets we make for shop projects we finally going to stock some of these parts to sell to the home builder. These brackets are all laser cut and designed with long tabs to be trimmed to fit to your desired shape for the location you choose for mounting difficult parts like a GM LS1 Engine Control Unit.
Or an LS2-LS7 Engine Control unit. ( $25 )
We also added a fuse panel shelf that has a tab to mount and GM style fuse panel to also. ( $45 - ECU mount and fuse panel shelf with mounting tab )
We have ISIS mounting plates in steel and Aluminum ( $12 buck each )
Transmission control unit mounting brackets ( $25 for the Unit with mounting holes and 40 for the 2 piece TCI style mount )
FAST XFI and XIM Mounting brackets ( $25 Each or $35 for the Combo mount)
Lokar E brake mounting bracket - ( $25 )
All parts that need to be welded are unwelded so you can modify position if desired. Plus all these parts fit in a Flat rate shipping box from USPS. 14.95 ships all that fit in one box.
Old 11-11-2010, 06:33 PM
War's Avatar
War War is offline
I could have used these a month ago. I had to make mine. I have no brains.
This will save someone with the brains to buy them hours of time. Great Idea.
Jason
Old 11-11-2010, 07:37 PM
NAPA 68 NAPA 68 is offline
I am in need of an LS1 bracket. Please let me know what you need from here.
Thanks!
Old 11-11-2010, 11:23 PM
BBPanel BBPanel is offline
Default LS1 Bracket
I could use an LS1 bracket as well - will try to stop by and pick one up soon. -Bob
Old 11-12-2010, 07:35 AM
ironworks's Avatar
Sounds Good.
Old 11-12-2010, 07:36 AM
ironworks's Avatar
Thanks!
If all you need is one bracket, it would be 25 bucks plus 14.95 for shipping. You can paypal the money to [email protected].
If you need anything else the shipping price is the same.
Old 11-12-2010, 07:53 AM
Done!
Old 11-12-2010, 08:01 AM
ironworks's Avatar
Done!
The Bracket is setting in the box labeled and waiting for the Mail Man. Post pics when you get it installed. Thanks again.
Old 11-12-2010, 09:10 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Nice brackets Rodger! This should make it easy for some people mount their electronics..
Cris Gonzalez
Old 11-12-2010, 10:02 AM
ironworks's Avatar
That's the plan
